+ Reply to Thread
Results 1 to 6 of 6
Thread: Question about a tire air pressure reader
    Douglas is offline Board Regular Douglas is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2005
    Tifton, GA
    278
    Default Question about a tire air pressure reader
    I have an electronic air gauge used to check the air pressure in tires. It says it won't read past 99 psi.
    My question is, if I used it to check the tires in a commercial vehicle and the pressure was 100 psi or over, WOULD IT TEAR MY AIR GAUGE UP??
    If not, I could still use it to check the tires, and if it didn't read I would know it was at at least 100 psi (where it's supposed to be) if it's below, it should read. :?: :?: :?:
    Be calm in the face of all common disgraces and know what they're doin' it for - G. Lightfoot
  2. #2
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    i would just buy a truck air gauge. i always have 110 lbs min in my tires. too much air put to gauge can blow seal in it.
  3. #3
    silvan's Avatar
    silvan is offline Senior Board Member silvan is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2006
    East Coast
    856
    I have another question on this topic. I like a dial gauge. I have one for my car, and love it. I wanted one for my truck, and finally found one. It looks nice, but it has some problems. The stem is so short that it's impossible to take a reading off inside duals. I can't get it to make a seal, or spin the dial to a position where I can read it. All I do is let more air out every time I persist in the futile effort. On outside duals, it only gives me a reading about half the time, and then it only reads after several seconds.
    It has a brass tube with a little brass button on the side. I can't figure out what the brass button is for, and the instructions don't mention it.
    I think the thing is probably busted, and probably useless even if it isn't busted, since it won't give me a reading from inside tires.
    I'd like to buy a real one that actually works, because I hate the little shoot-out style tire gauges, but I can't find anything like this online, and the one I bought is the first time I've ever seen a dial type pressure gauge in a truckstop.
    Also, will a TA take something like this back? I think mine is defective, and if it's not, it's still useless. A big waste of $30 on nothing. Humbug.
  4. #4
    Part Time Dweller's Avatar
    Part Time Dweller is offline Board Regular Part Time Dweller is on the right path.  You could probably safely loan them a quarter.
    Jan 2007
    Western Chicago Suburb, IL
    442
    This is what you need silvan; Milton Industries, model s 909. The button is to release the pressure after reading it.
    https://www.miltonindustries.com/upl...ages_50-51.pdf
  5. #5
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by Part Time Dweller
    Actually Mark, the S986 would be best for checking inside duals with aluminum Budds.
    It has a straight end which is what you need to get square with the valve stem when working thru those small rim holes.
  6. #6
    Jan 2007
    442
    Silvan stated he liked the dial type gauge, which the s909 has. :wink:
    There is a digital gauge with the style chuck you mentioned available;
    http://www.myerstiresupply.com/pls/m...rt_id=kdtm3653
    These extensions are also available, which make checking the inner wheels easier. We use these on all our trucks and trailers.
+ Reply to Thread
