+ Reply to Thread
Results 1 to 11 of 11
Thread: Oil Analysis Results ---Your Opinions Please
    Red Clay Rambler's Avatar
    Red Clay Rambler is offline Board Regular Red Clay Rambler is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Oct 2006
    Tennessee
    359
    Default Oil Analysis Results ---Your Opinions Please
    This truck/engine is one that I am considering for purchase. I realize that oil analysis is most useful to establish patterns from test-to-test, but still wanted to see if anything glaring jumped out at me in the results. Here is all the info I have:
    99 International, Cummins ISM 370. OD miles are 630,000 ECM miles are 504,000. Date/mileage of last oil change are unknown.
    Test results:
    Aluminum 7
    Chromium <2
    Copper 9
    Iron 44
    Lead 13
    Tin <2
    Silicon <2
    Potassuim <2
    Sodium 15
    Moly 2
    Water <0.1
    Oxidation 7.3
    Visc@100 15.6
    Glycol ND
    Fuel <2.0
    TBN 7.5
    Nitration <2.0
    Soot 3.0
    Speedco test info says that soot is a little high, otherwise doesn't mention any other readings as being abnormal. According to notes I took from an interview with the Gulf Coast Bypass Filters guy, sodium might also be considered a little high.
    Comments?
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Do you know what kind of oil was put in?
    What are the units of measure for oxidation?
  3. #3
    Oct 2006
    Tennessee
    359
    I do not know what kind of oil. Info from Speedco result report says Oxidation is measured in "absorbance units".
  4. #4
    Aug 2005
    3,181
    Too bad, that's a shame.
    With this type of oil, and that many miles(whatever that is) this oil analysis basically is showing you right at the limit of when oil changes should be done.
    3% soot is high. Between that and oxidation, the viscosity of the oil has increased a bit(probably). But without knowing which oil was used, you can't really tell.
    The metal wear numbers look a little high too. But again without knowing how many miles, you can't tell. You need to know the wear metal rate to get a meaningful analysis.
    Here are some other analysis' (including mine)
    http://www.dabsrepair.com/oilsamples.html
  5. #5
    Oct 2006
    Tennessee
    359
    Thanks Allan5oh, sorry I don't have more info. I think I found the name of the company that purchased the truck new. Maybe they can give me more info if I give them the VIN, etc. They might be the most recent owner, maybe the only one.
  6. #6
    rvrjr7 is offline Board Regular rvrjr7 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jul 2005
    229
    numbers looked good to me i know my samples if something is leading into problems the readout says to check what ever the high numbers might be comming from. i pull a sample every 12000 miles if i go up to 15000 my wear metals go up high
    high soot might be because of idling too much
  7. #7
    Apr 2005
    Spartanburg, SC
    42
    Hi Red Clay Rambler. Would you be able to ask the owner for previous oil analysis tests? Speedco does all of mine and on each page I have the current test AND the 2 previous tests to compare. It would be nice if you could compare this test here with the previous test and others before. I'd ask him, or, if you wanted to go through some extra trouble, get the Unit # and company and go to Speedco and ask if they have a record for that Unit.
    Good Luck!
  8. #8
    Apr 2005
    Spartanburg, SC
    42
    Default Re: Oil Analysis Results ---Your Opinions Please
    Quote Originally Posted by Red Clay Rambler
    Test results:
    Aluminum 7
    Chromium <2
    Copper 9
    Iron 44
    Lead 13
    Tin <2
    Silicon <2
    Potassuim <2
    Sodium 15
    Moly 2
    Water <0.1
    Oxidation 7.3
    Visc@100 15.6
    Glycol ND
    Fuel <2.0
    TBN 7.5
    Nitration <2.0
    Soot 3.0
    Comments?
    Here are my readings to compare with. Keep in mind, this is an over-hauled (out of frame) motor and it now has 175,000 miles on it. It is a Detroit 60 and I use ONLY Mobil Delvac 1300 Super. I change mine every 12500 miles.
    TRUCK MAKE: FREIGHTLINER
    TRUCK YEAR: 1998
    ENGINE MAKE: DETROIT DIESEL
    SUMP CAPACITY 40.0
    ALUMINUM 2
    CHROMIUM <2
    COPPER 6
    IRON 10
    LEAD 9
    TIN <2
    SILICON <2
    POTASSIUM <2
    SODIUM 5
    MOLY 14
    WATER <0.1
    OXIDATION <0.1
    VISC@100 14.8
    GLYCOL - ND
    FUEL <2.0
    TBN 8.3
    NITRATION 2.8
    SOOT 1.9
    ALL ENGINE WEAR RATES NORMAL. SAMPLE APPEARS FREE OF EXTERNAL CONTAMINATION. ANALYSIS INDICATES PROPER PERFORMANCE OF THE LUBRICANT AND UNIT.
    I have the "Understanding Your Report" also, but it would take up an entire page. You could get this from Speedco.
  9. #9
    Maniac's Avatar
    Maniac is offline Senior Board Member Maniac is on the right path.  You could probably safely loan them a quarter.
    Sep 2004
    Northeast
    956
  10. #10
    Aug 2005
    3,181
    Quote Originally Posted by carolinatrucker
    LEAD 9
    This is high, definitely for the amount of miles. However, you said this is a fresher engine. Lead indicates bearings. Keep an eye on this.
    VISC@100 14.8
    Viscosity is decent.
    TBN 8.3
    Lots of acid-neutralizing left in this oil. You could extend it if you want.
    SOOT 1.9
    Soot is *high* for the mileage. Very high. Get your injectors checked out, keep an eye on this. Do you idle the truck a lot? Consider getting a bypass filter. Your engine could really use it.
    If this is all speedco gives you, I'd suggest going with a better lab. There are many more things you want to keep an eye on. Also, does speedco use one of those "desktop" units or do they send away to a lab? The second is much much better.
  11. #11
    Apr 2005
    Spartanburg, SC
    42
    Default Injector DID go bad
    Hello Allan. Thanks for the great post and reply. Sure enough, one of my injectors went out this morning and I've taken it to Detroit Diesel to be repaired.
    You mentioned an "oil bypass" unit. What is that? How does it work? Where would I get it? What are the benefits?
  12. This ad will disappear if you login
+ Reply to Thread
