One of our trucks has a tranny issue. Everything shifts right except when your going from high to low. From low to high it's ok but if your, let's say slowing down and go from high range to low range it clunks in, rather loud and you can definitely feel it. The only time it does not do it is when your completely stopped or moving very slow, like 2 mph, then it sounds normal. We have had someone tell us it might be some sort of pressure regulator in the tranny that is only supposed to get about 60 psi but might be messed up and not delivering the right pressure to the system. It's a 1993 Pete 378 425 CAT Eaton 18 speed. We just found out the truck had a 18 speed. It originally had a 13 speed because everything on the truck states that and also my boss bought it like that but the driver and I were talking and he mentioned he could split the low side and I happen to drive it a few days later and sure enough you can. I told my boss this and he wouldn't believe me so we crawled under the truck to look at the tranny tag. He believes now. I've driven it quite a bit when the driver is out and my boss has driven it a lot in the past but we both assumed it had a 13 speed so we never attempted to split the low side. The gears the truck has you can hardly tell the difference on the low side splitting gears. They're so close it's not much use. Anyways, any other ideas on the high to low clunk ?
8) 8)
