+ Reply to Thread
Results 1 to 6 of 6
Thread: Bumper light wiring question
    Default Bumper light wiring question
    I just put a new bumper on my truck and I got one with 9 oval light slots. I bought the lights and a wiring harness. The thing that puzzles me is that there are 3 wires for each light. I haven't hooked them up yet and I'm sure I'll figure it out but only 2 wires are required for 12vdc operation. I'm assuming these could be used for directional lights also hence the third wire?
  2. #2
    TK THE TRUCKER's Avatar
    TK THE TRUCKER is offline Senior Board Member TK THE TRUCKER is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jul 2004
    Macedon Center,NY
    1,024
    Default Re: Bumper light wiring question
    Quote Originally Posted by SteveBooth
    Sounds right to me. You could have each half blink for that side or maybe just have one or two blink on each end and leave the middle ones as just running lights. That's what I would do if it were me Just make sure you secure the harness real good so ice and snow that accumulates on the wires doesn't rip them out since this is low to the ground and road spray will be blasting that area even though it's on the backside of the bumper.
  3. #3
    Quote Originally Posted by TK THE TRUCKER
    Good point, I never would have thought of that!!!
  4. #4
    Jumbo's Avatar
    Jumbo is offline Senior Board Member Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street.
    Aug 2006
    Northern Wisconsin
    2,102
    Are they a three plug style pig tail? There should be red, black and white
    wires. Black is your power. White is the ground. Red is turn and brake. If you just want them to come on as running lights just connect the black and white wires(and I don't mean together). Do you have electrical grease? Before you plug each light in fill the female ends on the light with that grease, It just keeps the corrosion down. We usually unplug each light and refill with grease about twice a year.
  5. #5
    Quote Originally Posted by Jumbo
    Yup. They are already greased up inside the socket. Thanks for the tips!
  6. #6
    Jumbo's Avatar
    Aug 2006
    Northern Wisconsin
    2,102
    You should smear a little bit more on each one. Not just what is inside of them now. Grease the face of the plug to keep the water out. It seems like over kill but if it is done now it saves you headaches down the road, especially if you have to start cutting into the harness to replace pigtails.
+ Reply to Thread
