I just got into my '05 Pete, and will try and give you as much information as I can.
First off, it just had it's B-Service approximately 2000 Miles ago (when I got the truck). It has a new fuel filter which is not showing signs of being clogged, it also has 2 new air filters which is showing a maximum of 2 Inches H2O.
Engine: Cummins ISX rated at 475 Horse
Exhaust Brake: "C" Brake
Transmission: Eaton Fuller 13 Speed
Here are the issues that I am having.
- *Exhaust brake intermittently works when running with cruise off.
*Exhaust brake does not work at all with cruise on.
*Regardless of weight or if I am loaded for that matter, speed falls off very rapidly and either have to down-shift at the shallower base of a hill. (I know that I can expect deceleration, but not as fast as this is losing speed).
*When the R's get down to around 1000-1200 it is making the equivalent to a "coughing" noise and have to down shift.
*When I am idling, it is idling really rough around 500 R's
I was told that there is possibly some blue smoke coming from my stacks, however it was not consistently happening.
On a side note, the truck was struggling going up White Bird (US 97) and when I was on a 6% grade, I was averaging 22-25, and when it went to 7% grade, I was averaging 19-22. Fan was on, Heat was on, A/C was turned off.
Stats:
- *Oil Temp: 230
*Water Temp: 190-200
*Transmission Oil Temp: 175-200
*Pyrometer: 700-800
*Oil Pressure: 30-35
*Manifold Pressure: 20-30
*Outside Temp: 68-72
If anyone has ideas, I'd appreciate it.
