+ Reply to Thread
Results 1 to 7 of 7
Thread: 2nd oil analysis came back, some copper again
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Default 2nd oil analysis came back, some copper again
    http://www.oilanalysis.net/CommonFil...I=DABWIN_61966
    227 ppm on 52,000 km
    changed oil and filters
    21 ppm on 11,000 km
    gone from a part of copper every 229 km to 524 km.
    I still don't like it. Every single UOA I look at copper is below 1. 1 PPM / 40,000 km or something like that.
    Only thing I can do is do another analysis around 30k. If copper is still going up at a regular rate, at this point it is becoming a regular wear metal and we can eliminate anything irregular like gaskets or oil cooler.
    At that point, the engine would probably have to come apart.
  2. #2
    duck is offline Member duck is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2006
    Green Bay - Wisconsin
    128
    Km on truck - over all?
    If it's a CAT - it's part of the oil cooler wearing in - they have a little sheet on it avail at CAT dealers.
    Your PPM don't really scare me that parts per MILLION. She starts hitting 700-1000 then I would get nervous. Any other elements? Lead or Iron?
    Andrew
  3. #3
    Sep 2006
    128
    Found your other post - I guess it does bear looking into then. Oil cooler is 3 years old - then maybe - what I was talking about usually shows around the 3rd oil change on new CAT engine.
    Andrew
  4. #4
    Oct 2006
    Nb
    794
    Default Re: 2nd oil analysis came back, some copper again
    Quote Originally Posted by allan5oh
    http://www.oilanalysis.net/CommonFiles/reports/RPT_WCA.asp?ReportPage=RPT_WCALVL1.asp&LabId=24382 34&WUI=DABWIN_61966
    21 ppm on 11,000 km
    alan, weren't you do some experimenting on extending oil change intervals, etc? are you changing it based on the results of the analysis? what is your current (and recent past) oil change schedule?
    try sending a sample to a different company
  5. #5
    mrpersons is offline Member mrpersons is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    tidewater area of Virginia
    178
    allan5oh I've been watching with interest concerning your elevated copper levels. I can't see how any gasket material or contents of an oil cooler could result in a elevated copper count, they are not "wear" points.
    Seems you mentioned somewhere that you were using some kind of oil other than commonly used. Might I sudgest that perhaps it has something to do with the formulation of the oil? Sending in a sample of new oil would reveal that if it's so.
    The only thing I think of that might show up as copper is a defective water pump seal. Usually made of a ceramic material against a stainless or brass wear surface, but that's pushing it. It's more likely to show up as coolant in the oil.
  6. #6
    brian is offline Senior Board Member brian has a checkered past and should take up chess.
    Jan 2005
    over here
    1,012
    bearing base material is usually copper, I didnt see the other thread so whats the whole story?
  7. #7
    Aug 2005
    3,181
    Using shell rotella T, considering switching to synthetic. But if I'm not 100% sure on the engine, there's no point switching to something more expensive.
  8. This ad will disappear if you login
+ Reply to Thread
