+ Reply to Thread
Results 1 to 5 of 5
Thread: What do engine oil temps typically run at?
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Default What do engine oil temps typically run at?
    As the topic says.
  2. #2
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    Mine runs around 180, just like the engines used to. :wink:
  3. #3
    Maniac's Avatar
    Maniac is offline Senior Board Member Maniac is on the right path.  You could probably safely loan them a quarter.
    Sep 2004
    Northeast
    956
    Should be within engine operating temp, 180 to 200 degrees
  4. #4
    Bandit102's Avatar
    Bandit102 is offline Board Regular Bandit102 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    Denver, CO
    338
    What I look for in +/- 10 degrees F (approx) of what the water temp. is if the engine uses an oil to water heat exchanger. With no oil cooler, 200-210 F seems to be what I've seen. Seems like I read that engine oil is engineered to perform well at around 210F. Just my 2 cents and by no means manufacturer's technical data.
  5. #5
    Mifirewoodguy is offline Member Mifirewoodguy is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2006
    Waterford,Michigan
    79
    N 14 cummins Im running 180- 200 and the fan kicks in at about 210
+ Reply to Thread
