Results 1 to 12 of 12
Thread: Coolant leak
    jp207 is offline Rookie
    Apr 2007
    22
    Default Coolant leak
    I have a 97 Century with a 430 detroit. It is losing coolant, quickly. 1-3 gallons a day depending how hard it is working. Engine has 920K on it. We believe it is a head gasket, the only place I can see coolant leaking is out of the block at the right front of the engine. Seems to be a slow slow leak though. No steam from the exhaust, no water in the oil. The engine runs really well, averaging 7+ MPG and can pull mountains with relative ease. The engine holds a solid 50PSI oil press. at cruise and about 30PSI @ 600 RPM idle. My mech tells me to inframe it, he can replace the head gasket for alot less than inframe, but tells me it is wasting money to do the head gasket and not inframe it, since it is already apart. What would you do? 920K is pretty high, but man it runs great other than losing coolant. !!
  2. #2
    Oct 2006
    Nb
    794
    Default Re: Coolant leak
    Quote Originally Posted by jp207
    the worn liner walls will be very visible once the cylinder head is off...
    920K? it's due
  3. #3
    Aug 2005
    jackassville (winnipeg, mb)
    3,189
    Has the rad ever been replaced?
  4. #4
    Apr 2007
    22
    920K? it's due
    Yeah, it's up there...Problem is money..I simply cannot afford to do the whole engine...So it's getting a head gasket replaced...I'm going to go to the truck repair shop tomorrow and take a look inside at things with the head off..
  5. #5
    yoopr is offline Board Icon
    Nov 2004
    12,865
    That's ALOT of Fluid
    Radiator has got to be replaced or you're gonna end up with some serious problems on the road.
    Until then give Bars Leak a whirl for a temporary fix but just Temporary.
  6. #6
    Aug 2005
    3,189
    sounds like your mechanic is just stabbing into the dark. You ARE wasting your money doing that head gasket, unfortunately.
    With that much fluid loss, it should be very easy to tell.
    Does your exhaust put out a lot of white smoke? Any at all after it's warmed up?
    What does the bottom of the rad look like? They tend to rust quite bad in the northern "salt states" after 4-5 years.
    Has your mechanic run a hot pressure test?
    I have a feeling when you go see the mechanic he's going to convince you that you need an inframe.
  7. #7
    Nov 2004
    12,865
    Pressure test should show them where the problem is.
  8. #8
    Oct 2006
    Nb
    794
    Quote Originally Posted by yoopr
    ...seems like an easy find to me...
  9. #9
    Apr 2007
    22
    The problem is quite obvious...The coolant was running down the side of the engine. Right front corner.
    The truck is fixed and running now. The head gasket clearly shows the story. I was able to get a look into the cylinders and at the head...Everything looks really good...Cylinder walls still had the cross hatch in them. Truck is no longer losing water.
    I believe this engine will last a good bit longer. You can't argue with 50PSI of oil pressure, 30PSI at 600RPM hot, and clean oil analysis results.
    This repair cost $2350...Seem about in line?? A lube/oil/filter was also done, along with injector o-rings..
  10. #10
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,189
    i had a neighbor who had same problem. he was losing water thru overflow hose on water tank. it was head gasket. the truck had 800,000 & he could not afford rebuild. he had head resurfaced & new gasket. that cost total 1,900. that was 3 years & 270 thou miles ago. so for him it was worth not doing the rebuild. truck still runs 2-3 thou mi a week..
  11. #11
    Oct 2006
    Nb
    794
    [quote="heavyhaulerss"]i had a neighbor who had same problem.
    that is a completely different failure; he was leaking compression to the cooling system, this engine was leaking coolant externally
    he was losing water thru overflow hose on water tank. it was head gasket. the truck had 800,000 & he could not afford rebuild. he had head resurfaced & new gasket. that cost total 1,900. that was 3 years & 270 thou miles ago. so for him it was worth not doing the rebuild. truck still runs 2-3 thou mi a week..[/quote
  12. #12
    Apr 2007
    22
    Yes, this was not leaking coolant anywhere else but to the outside of the engine. Thankfully.
  13. This ad will disappear if you login
