after hitting 1 million miles last week without ever having any work done on my detroit, yesterday i got my first breakdown in over 7 years. my truck started running rough. like if you had a spark plug wire off on a gas engine. i took to shop & we checked the oil. it was overfull by 2-4 gallons. truck will be looked at by friday hopefully. shop mgr said sounds like injector leaking down.(this may explain why it was hard starting during cold months) anyway.. you can smell fuel in the oil. no doubt that was losing it's prime & causing the rough shake when trying to excellerate. could this be just an injector bad or injector sleeve? or can there be many more things that can cause fuel to get in oil ? what would be the worst case senario?
