Results 1 to 5 of 5
Thread: correct idling r.p.m.
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,189
    Default correct idling r.p.m.
    what is the correct r.p.m.'s for a 11.1 detroit motor to idlle, when running truck overnight? is there different r.p.m's for different temps?
  2. #2
    Twister is offline Rookie
    May 2006
    Mississippi
    7
    We usually set ours to run at 1000-1100 if idling for extended periods. This works well to help A/C in the Summer and also with heat in the winter. This also prevents loading a cylinder with fuel eliminating cold smoke when you gas on it. We set 12.7's and 14's the same way.
  3. #3
    Oct 2006
    Nb
    794
    Quote Originally Posted by Twister
    idling at base engine idle speed (6-750rpms) will cause cylinder liner glazing... then blow-by, the pistons have to be pulled to correct this condition
    diesel engines should not fall below 165 deg f during long idle periods
    pay attention to anti-idling laws. there is a free guide on;
    http://www.onan.com/images/apu/f-1715.pdf
  4. #4
    roadranger is offline Board Regular
    Sep 2005
    Junction of MA CT RI (Putnam CT)
    246
    I boost my idle up just enough to stop the loud rattles in my old Freightshaker - about 800 RPM does it. Can't sleep at the normal idle of 600 RPM .
  5. #5
    yoopr is offline Board Icon
    Nov 2004
    12,865
    Quote Originally Posted by roadranger
    That's true-I idled mine around 8-900
