what is the correct way to flush the entire cooling sys on a big truck. to be specific a detroit engine? can a person do it himself, or is this something that needs to be done by some expert with specific knowledge of the cooling sys? my temp is rising faster than used to & if left idling temp climbs lil faster than used too. everything on truck o.k. new water pump, new thermostats, new hoses, head gasket o.k. but never had radiator or cooling sys flushed. thinking this may help?????
so much for looking down the fill hole and guessing the level. The bad cap was also causing it loose coolant. It's cools fine now.
