Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Maintenance Manual for a 2000 Freightliner FLD
  1. #21
    Oct 2006
    Nb
    794
    Quote Originally Posted by raymundo1
    That was right on Bob! I got the part and it is fixed!
    I took some time off and replaced the brake pads and the drums on all of the back axles.
    That was heavy but easy enough until I found a lot of grease on one of them. The grease of course was coming from the S cam, got the kit and replaced the seals and also the oil seal. Looks and I hope that I did a good job (wouldn’t want to do it again!) I’ll keep an eye for leaks, slacks re-adjustments and wheels torque.
    There is another small problem I would like to have your advice , my air recycle valve (the one on the AC/heater panel) is not working properly, I can hear it closing but it won’t stay closed, do I have to replace it or is there a way to fix it?
    Thanks again for all your help y Feliz año Nuevo amigo!!!
    did you pull the hubs... or just drums?
    what make/model truck?
    there could be something blocking closing of the fresh air door?
  2. #22
    raymundo1 is offline Rookie
    Dec 2006
    NM
    21
    I only pulled the hub on the one I replaced the S-cam bushings. I checked the play on the other S-cams and they were not too bad so I left them alone.
    Freightliner 2000 FLD120
    As far as I can see there is nothing blocking the air door, and as a matter of fact, it was working not too long ago.
    Jose’
    "Heading on the Highway"
  3. #23
    Dec 2006
    NM
    21
    Brakes are working good and the push bottom recycle valve was bad so I replaced it. I'm a happy trucker now, thank you for all your help specially to you Bob.
  4. #24
    Oct 2006
    Nb
    794
    ...good job, ray
