+ Reply to Thread
Results 1 to 8 of 8
Thread: truck doesnt idle well
    tonyj1981 is offline Rookie tonyj1981 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    5
    Default truck doesnt idle well
    Ok i just had a inframe dome on a 2001 freightliner witha 475 isx. I idles very ruff, and seems to have weird vibrations around 60. my oil pressure is only about 30psi.
  2. #2
    Krzysztof is offline Member Krzysztof is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    Marion, AR
    149
    Take it back to whoever did your inframe?
    -Krzysztof
    Keep the rubber side down on the hard stuff.
  3. #3
    Oct 2006
    Nb
    794
    Default Re: truck doesnt idle well
    Quote Originally Posted by tonyj1981
    The overhead set was done wrong.
    Why, is 30 low? What is it normally?
  4. #4
    Diesel Nut is offline Rookie Diesel Nut is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    Nova Scotia, Canada
    5
    Default Isx-475 running rough
    Has it been running rough sense you got it back or did it start sometime after you got it back ?
    Sounds like a bad metering or timing actuator (possibly?)
    If the engine runs on after it is shout off it could possibly be an injector check ball not seating = you will need a new injector to fix that.
    Was this "Rebuild" done at a Cummings dealer OR distributor ??
    === eather way you should take it back and have that Tec. check it out.
  5. #5
    Nov 2006
    5
    Quote Originally Posted by bob h
    It should be around 35 to 45 psi. I hAd the overhaul at a Cummins dealer.
  6. #6
    Oct 2006
    Nb
    794
    Default Re: Isx-475 running rough
    Quote Originally Posted by Diesel Nut
    Cummings???
  7. #7
    Oct 2006
    Nb
    794
    This is too easy... it just had an in-frame, now you have rough idle and low oil pressure - TAKE IT BACK!!!
  8. #8
    Nov 2006
    Nova Scotia, Canada
    5
    Cummings???
    _________________
    SORRY Bob, I had a couple of beer and mistakenly put a "g" in Cummins.
    My apologies to eveyone, Diesel Nut.
  9. This ad will disappear if you login
+ Reply to Thread
