For years I have been changeing oil at 12-15k, per what the engine/truck manufacturer recommends. Even when Speedco came along with "on site" oil analysis, I was dumping the oil, then reading the results of the analysis afterchangeing the oil. When I finnally read the results, I came to the conclusion that there was no reason to have changed it! By this I mean there was no abnormal wear metals present, soot levels were good, viscosity good, TBN# well within limits, etc, etc. I'm not using any exoctic oil here, just good 'ol Rotella t. Engine is a 3406E w/450k in normal use. Since I have an APU, I seldom idle.
For the past two years, instead of just pulling in, and letting them dump the oil, I've been requireing them to take an oil sample and analyise it before I make the decision to change it or not. I kid you not, at 45k, the oil has been well within tolerance everytime. I'm sure the lack of idleing has a lot to do with this, and the engine itself is obviously in good shape.
Normal PM oil change has been running me about $230-260 with cat filters, the other day I went in and had an analysis done, installed new fuel filters, and greased everything. (didn't need oil changed) $67. Obviously saving a few of my hard earned bucks, in fact quite a few over the 2 yrs I've been doing this.
Just thought I'd share this plan with u'all, see what ideas you might have. I might be doing something wrong here, but I'll be danged if I can figuire out what it might be.
Questions might range to warranty? In my case doesn't apply, engine is over 5 yrs old.
Just for giggles, I"ve had Speedco test new oil to check thier equipment, seems to be accurate everytime.
Your thoughts??
