+ Reply to Thread
Results 1 to 12 of 12
Thread: Air brake anti freeze
    COLT is offline Senior Board Member COLT is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    FT ST JOHN
    650
    Default Air brake anti freeze
    You have to put it in your air tank, the wet tank. Just pull out the bung bolt off the top and pour a quart in, with glad hands, I like to use a top from a bottle of dish soap, sprayinwash, or something like that type of squirt bottle, Gatorade ? Whatever... If it's your trailer, pull the plug and just dump a bottle in the air tank. some of those bottle caps fit the air brake bottles. Just trying to help
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    I've seen guys pour half a litre of that stuff into the red gladhand. Turns out theres just ice on the mechanism. Just because a brake wont release, that doesn't mean it needs alcohol.
  3. #3
    Jan 2006
    FT ST JOHN
    650
    Oh, I know, I've been dealing with froze up brakes for 3 weeks, too much snow! I have had good luck with the " 100 lb" application on and off method Every morning I have a couple wheels froze. Gotta get a look before you go! OR you will look stupid with flat spots. Expensive too.
  4. #4
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    Quote Originally Posted by allan5oh
    I agree - a little tap with a hammer will do wonders.
  5. #5
    Aug 2005
    3,181
    Quote Originally Posted by COLT
    I'm a lazy bastard too!
  6. #6
    Jan 2006
    FT ST JOHN
    650
    Banging thecrap out of your dust covers... if you have buds... It's hard to hit the drums. WARM your brakes up before you park, don't set your trailer brakes. duh
  7. #7
    Oct 2006
    Nb
    794
    alcohol destroys air brake valve seals... as does methyl hydrate, that's why you should only use real air brake anti-freeze.
  8. #8
    Oct 2006
    Nb
    794
    Warming the brakes before parking can cause condensation to form on the surface of the drum... freezing the shoe lining to the drum; that's why striking the drum will let the brakes release. Try letting the brakes cool before applying the park brake... see if that stops the freezing.
  9. #9
    Jan 2006
    FT ST JOHN
    650
    I was talking about melting the snow that is in the drum
  10. #10
    Oct 2006
    Nb
    794
    ok
    make sure that no water (melted snow) is left in the drum... same problem ;0)
  11. #11
    Blacksheep is offline Senior Board Member Blacksheep is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2005
    any place I please
    1,310
    Just a tip for you little leaguer's out their, make sure you drain the air tanks prior to removing any plugs.
    Otherwise you will not be a happy camper, Roger ? :wink:
  12. #12
    Oct 2006
    Nb
    794
    Quote Originally Posted by Blacksheep
    LOL!
    ...and the air lines too, especially the little ones, the welt is just like you would get from a whip!
  13. This ad will disappear if you login
+ Reply to Thread
