Are the tires running true (is it wobbling side to side or bouncing up and down)? You need to look at this yourself, the techs will ignore it.Originally Posted by Neckster
What do you mean by "spin-balancing"... on or off the vehicle?
An egg-shaped tire will balance, but the heavy side will cause it to "tramp" or slap the road as it spins under a load.
Tell them sternly; "There was no shaking before the tire replacement... why is it shaking now?!?"
If you want to verify the alignment - - place a protractor or angle finder...
http://images.google.ca/imgres?imgur...lr%3D%26sa%3DN
...on the flat part of the axle just beside the springs/u-bolts... then, post what you find.
