+ Reply to Thread
Results 1 to 7 of 7
Thread: C15 BRIDGE ENGINE
    COLT is offline Senior Board Member COLT is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    FT ST JOHN
    650
    Default C15 BRIDGE ENGINE
    I had a 550 Acert before, didn't like it, now I have a 01 C15 550, pulls good with the wastegate hose pinched. I will be in a 550 bridge soon, what can I expect for power? cpu regulated wastegate, catalytic mufflers. What else can you tell me?
  2. #2
    Oct 2006
    Nb
    794
    Default Re: C15 BRIDGE ENGINE
    Quote Originally Posted by COLT
    They're yellow... don't pinch off the line.
  3. #3
    Jan 2006
    FT ST JOHN
    650
    I just started to move into my new ride, found out it's an 03 C15 Last year of the good ones! What did you mean Bob, when you said not to pinch the wastegate hose? P.S. Cat finely has a fix for the rocker arms! only took 5 years.
  4. #4
    Oct 2006
    Nb
    794
    blocking waste gate actuator hoses will cause the turbo to; overspeed, overboost, and self-destruct. the cause of the failure is easily determined and voids engine warranty.
  5. #5
    Jan 2006
    FT ST JOHN
    650
    NAH, your s*#ting me... They just run cooler pyro temps, more pollution. I haul in the bush, no city driving.
  6. #6
    Oct 2006
    Nb
    794
    how much boost? how low do you lug it?
    cooler pyro means lower NOx emissions.
    the problem isn't manifold temps or pollution - it's overspeeding the turbo.
    '03 still has warranty?
  7. #7
    Jan 2006
    FT ST JOHN
    650
    Warranty, ? 11000 hr's I don't lug too much, 18 speed. Sometimes I have to lug to get over the top of a hill "barefoot" about 37 lbs boost, set at 550 hp. I just got into this truck... normally a 550 is about 30 lbs boost. I've seen my pyro at about 1150 :shock: lugging, 850 whith the wastegate pinched. ???
  8. This ad will disappear if you login
+ Reply to Thread
