+ Reply to Thread
Results 1 to 8 of 8
Thread: truck alignment
    vontrial is offline Member vontrial is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2006
    MS
    121
    Default truck alignment
    I have a little shaking in my steering (front end) when I reached speed of about 55mph will smooth out at higher speed . Do you think I need a frontend alignment or could something else be wrong, no wear on my tires. Do any one use those wheel balancer. and if get the computerized front end alignment shop said that they can align truck from front to back, If anyone has had this done post and let me know what your opinion or results. Thanks
  2. #2
    marcel27208's Avatar
    marcel27208 is offline Senior Board Member marcel27208 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2006
    salisbury,NC
    1,049
    same thing happened on my truck about 2 years ago...it would shake real bad at 35-45 mph and then as i got to a higher speed it wouldnt do it anymore........got an alignment and took the problem away
  3. #3
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Get your front wheels balanced. Should be $30 each. How does the truck handle?
    I've heard too much caster can cause a shimmy. That would be resolved with an alignment.
  4. #4
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    Don't know about alignment causing shimmy, but balance certainly does. Had a set of tires that had to be re-balanced every 30K or so. I put on a set of Centra-matic balancers and have not had any problems since. If you're getting a shake at 55, you WILL have flat spots on your tires before long. Take care of the balance now. Alignment tends to wear off one side of the tires more than the other. Haven't heard of that causing any shake, only a pull to one side or the other.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  5. #5
    JAXLE67 is offline Rookie JAXLE67 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    16
    A caster shimmy usually takes slowing way down to get it to stop its shimmy. A caster shimmy is pretty violent feeling. Sounds more like a tire balance or a out of round tire. Jack it up and rotate front wheels to see any runout. My 2 cents
  6. #6
    Aug 2005
    3,181
    caster shimmy = shopping cart
  7. #7
    COLT is offline Senior Board Member COLT is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    FT ST JOHN
    650
    Funny Allan, Could also wash out your inside rims, front and back.
  8. #8
    Aug 2005
    3,181
    It's true! Shopping cart wheels have a lot of caster, that's why they shake like that!
  9. This ad will disappear if you login
+ Reply to Thread
