+ Reply to Thread
Results 1 to 13 of 13
Thread: Freightliner colimbia clutch
    Intrepid is offline Rookie Intrepid is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2006
    2
    Default Freightliner colimbia clutch
    I'm a new driver that is being assigned my first truck from my company. when I first inspected the tractor the clutch had no freeplay in the clutch peddle. I told the mechanics and they put about 1.5" of freeplay but by doing that it took away the clutch brake. I'm thinking the freeplay is more important then the cluch brake, Is that a correct assumption? should I ask the mechanic to put in the 2 to 3" that should be there? he told me I could have one or the other. what would you expirenced drivers do if you were in my shoes?
    thanks
  2. #2
    mrpersons is offline Member mrpersons is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    tidewater area of Virginia
    178
    1.5" on the freeplay is fine. Adjusting the clutch (if done correctly) should not have disturbed the cluch brake. A hint here. To get the truck in gear easier w/o a cluch brake, try shifting from a stop using the lowest gear, then shift to the one you wanted in the first place. Worked in the past for me.
  3. #3
    Mr. Bighead is offline Member Mr. Bighead is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2006
    136
    It's supposed to have 1.5"-2" of freeplay. If you lost clutch brake when you gained freeplay, that probably means your mechanic adjusted the linkage and not the clutch itself. If that's the case, he's an idiot.
    I think the devil drives a T2000.
  4. #4
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by Intrepid View Post
    thanks
    Evidently he adjusted the external linkage to get more free travel in the pedal, which is the wrong way to adjust a 14" 0r 15.5" pull type clutch (The type used in just about all modern class 8 trucks).
    These clutches must be adjusted internally by turning the adjuster on the pressure plate.
    The only time the external linkage should be adjusted is when setting up a newly replaced clutch, or if you're experiencing poor clutch brake operation, in either of those scenarios, you adjust the linkage for proper clutch brake squeeze, then adjust the pressure plate adjuster for proper free travel.
  5. #5
    Larry227 is offline Member Larry227 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2008
    British Columbia
    50
    What ^ they ^ said, unless it has an Eaton Solo in it. Solos are self adjusting and have to be reset manually or replaced. Either way you should end up with freeplay and clutch brake. Either the mechanic is an idiot or lazy or possibly both.
  6. #6
    Bandit102's Avatar
    Bandit102 is offline Board Regular Bandit102 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    Denver, CO
    338
    They said you could have either one but not both? BS. Idiots.
  7. #7
    Oct 2006
    Nb
    794
    Quote Originally Posted by Kranky View Post
    The linkage (1/8" free travel) should be adjusted AFTER the pressure plate adjustment (1/2" release travel).
  8. #8
    matcat's Avatar
    matcat is offline Senior Board Member matcat is on the right path.  You could probably safely loan them a quarter.
    Sep 2007
    Manchester, NJ
    1,469
    I am curious as to WHY free play is considered so important? The truck I am currently in needs to be adjusted, though it has the proper freeplay, but little brake, but at any event, WHY is free play so important? Hell I only use the thing to start and stop anyway!
    My Trucking Blog: http://matcattruckin.blogspot.com/
    Website I am making for drivers: http://www.4thedriver.com
    As I sit looking all around,
    Confusion and uncertainty is all I found.
    The answers are there,
    But I do not know where.
    Optimistic and hopeful dreams,
    Are all I have so it seems.
    The future I do not know,
    So all I can do is take it slow.
    But I do know it will work out,
    So I wait and watch without a doubt
  9. #9
    Oct 2006
    Nb
    794
    Quote Originally Posted by matcat View Post
    Free travel is the movement of the clutch release yoke (fork) BEFORE it contacts the release bearing. Any further clutch plate and disc wear beyond this point can hold the clutch partially released and can cause slipping/overheating. This does not happen with auto clutches as they are push-type instead of pull-type.
    Clutch pedal "freeplay" is the result of yoke free travel.
  10. #10
    Oct 2006
    Nb
    794
    Free travel is the movement of the clutch release yoke (fork) BEFORE it contacts the release bearing. Any further clutch plate and disc wear beyond this point can hold the clutch partially released and can cause slipping/overheating. This does not happen with automotive clutches as they are push-type instead of pull-type.
  11. #11
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    Quote Originally Posted by bob h View Post
    Ok that makes sense
  12. #12
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    I beg to differ.
    A push type clutch will also begin to slip and self destruct if run "tight" with no free travel in the pedal.
    The only difference is that with a push type automotive clutch you adjust the linkage to obtain free travel, instead of adjusting the clutch internally.
  13. #13
    Oct 2004
    CENTRAL JERSEY
    177
    just gonna have to get used to that ****ty shiftin freightshaker.
    LOW CLEARANCE BRIDGE MEANS NOTHIN TO A FLATBED
  14. This ad will disappear if you login
+ Reply to Thread
