+ Reply to Thread
Results 1 to 2 of 2
Thread: Gasket leak on the jake brake
    Mifirewoodguy is offline Member Mifirewoodguy is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2006
    Waterford,Michigan
    79
    Default Gasket leak on the jake brake
    I have found a leak or seep in the gasket/cover on the rear portion of our jake brake. Its on a 2000 N-14 cummins. Was just wondering if that's an easy fix by replacing the gasket or will I get into more than I bargained for if I try to replace it myself???
  2. #2
    Mr. Bighead is offline Member Mr. Bighead is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2006
    136
    It's an easy fix. Just remove the valve cover and the jake and put it back together with new gaskets. Technically, you're supposed to use a special feeler gauge to set the lash on the jake. If you don't have that feeler gauge, I wouldn't worry about it. The adjustment probably won't change at all.
    I think the devil drives a T2000.
  3. This ad will disappear if you login
+ Reply to Thread
