+ Reply to Thread
Results 1 to 14 of 14
Thread: Losing antifreeze?
    Jul 2006
    3
    Default Losing antifreeze?
    Got a 2001 Western Star with 3406E CAT. Having to add about a gallon of antifreeze everyday and no leaks. I'm thinking either head gasket or cracked head. Anyone have any ideas?
  2. #2
    Maniac's Avatar
    Maniac is offline Senior Board Member Maniac is on the right path.  You could probably safely loan them a quarter.
    Sep 2004
    Northeast
    956
    Sounds like it is internal, do an oil analysis ASAP if its in the oil pan you need to care care of it PRONTO, or risk losing the engine.
    Could also be a cracked liner.
  3. #3
    Jul 2006
    3
    I think that it has been doing this for maybe a week. It isn't my truck, but it's my girlfriends dad's. He hauls coal for himself and he doesn't want the downtime of it being in the shop a few days just for them to tell him what they think is wrong with it.
    I'll let him know.
  4. #4
    brian is offline Senior Board Member brian has a checkered past and should take up chess.
    Jan 2005
    over here
    1,012
    wouldnt take long for a shop to diagnose it, if he has a shop that will get him in right away, and he can`t wait around on this the longer it goes the more damage gets done.
  5. #5
    Jul 2006
    3
    That is true. He does most of the work himself, but something like that he was wanting to see if he could figure out the probably and maybe fix it himself without having to take it to the shop. He was asking me and head gasket or head was all that I could think of, but then again I'm still kinda learning heavy equipment stuff, I'm more of a car mechanic.
  6. #6
    Jan 2005
    over here
    1,012
    do you or him have the tools to do a leak down test? a compression test may lead ya in the general direction but a leak down test will damn near pin point it.
  7. #7
    COLT is offline Senior Board Member COLT is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    FT ST JOHN
    650
    Excuse the dumb question, Have you considered 1 gal low when cold is full when hot? I have seen this gallon aday ritual before. :wink:
  8. #8
    special k is offline Board Regular special k is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jul 2005
    Ontario Canada
    255
    If money is tight and it is steadily losing anti-freeze you can use some Irontite in the rad. I don't use those kinds of things but I know some guys that have bought some time using it. Keep a close eye on the oil for antifreeze contamination and pay attention when you start it to see if it leaking into the cylinder usually you get lots of whitish smoke. When that starts to happen you're gonna have to fix it soon.
  9. #9
    KAIMIKAZEE is offline Member KAIMIKAZEE is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2005
    135
    i've got the same 3406e in my pete....
    had the same problem a couple of months ago and it was a bad liner...
    so decided to get a complete overhaul....
    i too couldn't see any leaks and had to add a gallon every day.
    comes out to be somewhere like $50-70 bucks a weeks just for antifreeze.
    if your stacks are blowing bluish white smoke even after a long run than it's your liners, coolants getting internally into the oil
    hope that helps..
  10. #10
    C3 Trucking is offline Rookie C3 Trucking is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jul 2006
    1
    Default 3406e
    It is most likely a bad liner seal. Pull off a valve cover & look under the cover. If you see green/gray jelly like goo that is the water/antifreeze boiled out of the oil. Pull pan & pressurized a full rad with a rad cap checker. cat has a real problem with the 3400 series liner seals. 4 or 5 O ring material changes, so far same problem. The C-15 which is really a 3406E with most of the problems solved now uses the same crevice seal at the bottom of the liner that Cummins has used for 30 years. the liners most likely to leak are #1 & #2. They all can leak. It may or may not take some time to see the water drops on the crank after you apply pressure to the rad. Don't use more than 13-14 lbs pressure. If you do an in-frame when you pull the liners check the block for pinholes in the seal areas. Very small & not many holes can be sealed with cat epoxy, Large or many holes the cat service truck will be happy to come out & bore & sleeve the block for $300.00 per hole. Secondary cause might be the oil cooler. If it is running good not likely the head gasket. If you pull the head timing pins will help a lot, 3/8" bolt will work if you are careful. If you wait to long the oil filter will plug & bypass showing low oil pressure. Change the filter, oil pressure comes back strong. water makes a poor lube & will start to eat the rod & main bearings. If you drain the oil & it comes out jello you are in big trouble. If you in-frame check the cam bearings if you do not replace the head. You and everyone who owns a 3400 series sooner or later. Hows that for a sucky answer
  11. #11
    Mr. Bighead is offline Member Mr. Bighead is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2006
    136
    If you're really lucky, you could just need an air compressor. You would probably already know if it was putting antifreeze in your air tanks. It can also leak antifreeze into the oil. If they pull the pan to check for leaking liners, they'll check the compressor too.
    Of course, if you have anitfreeze in your oil, there's a good chance you could have bearing damage.
    I think the devil drives a T2000.
  12. #12
    Porchclimber is offline Member Porchclimber is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Oct 2006
    British Columbia
    65
    Antifreeze like oil finds it's own level.
    Keep some on hand but don't add any just to see what happens.
    Take a clear gallon jug and fill it with water and put your rad overflow hose in the jug with the engine running.
    Any bubbles?
    Another thing to check that has fooled many people is the small 3/16 line that supplies air pressure to the bunk heat/air switching valve.
    For some reason that line is at full system PSI and the valve will bypass air into the coolant causing the system to overpressure.
    There is no shutoff to the supply but if you take some vice grips and put something on the line to protect it then pinch the line off and check the overflow again for bubbles.
    Before getting too excited about head gaskets etc. I'd try that first.
    That's happened to me three times and I know of cases where dealerships have done the heads.
    But then again if you have warranty and they want to do the heads.
  13. #13
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    I used to drive a 3406 a few years ago. Got to a delivery in CO and noticed a "wet line" on the ground as I backed into the dock. When I checked it out, the radiator was leaking out the overflow. It was fuel. The injectors seals in sleeves with o-rings. one of the o-rings broke and it was pumping fuel into the coolant. But, depending on which ring fails, it can also pump coolant into either the radiator or into the cylinder. A gallon a day is a lot to lose.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  14. #14
    Oct 2006
    Nb
    794
    Quote Originally Posted by Windwalker
    When the engine is running, the fuel is at a higher pressure than coolant... therefore you get fuel in the coolant, causes overflow (with a fuel smell). When the engine is shut down, residual pressure from the cooling system overcomes the now "near zero" fuel pressure and pushes its way into the fuel --- Coolant in the fuel can be devastating to fuel system components, especially fuel injectors. It is quite unlikely for coolant to get into the combustion chamber from the injector sleeve... it actually gets there indirectly from the contaminated fuel in the tank.
  15. This ad will disappear if you login
+ Reply to Thread
