+ Reply to Thread
Results 1 to 6 of 6
Thread: Axle Load Gauge
    Oct 2005
    Wisconsin
    127
    Default Axle Load Gauge
    I never had a truck with one before so I'm not sure what it is reading.
    If anyone can fill me in on this I would appreciate it......thanks
  2. #2
    Howard is offline Member Howard is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Dec 2007
    52
    Default Load gauge
    The best way to figure that gauge out is to put your trailer tamdens where you want then ,then scale truck look at load gauge and write it down .Like on my truck 60pounds on gauge means my drives axles should be ok for weight. What the gauge is showing is air pressure on air ride on tractor. You could go somewhere flat slide trailer tamdens and see what gauge reads at different spots. Idid the scale way then you know .It's just help mate if not sure scale it . Hope it helps.
  3. #3
    Uturn2001 is offline Senior Board Member Uturn2001 is on the right path.  You could probably safely loan them a quarter.
    Jan 2005
    East Central IL between the corn and the beans
    4,982
    Every one I have seen is different. If you pull the same trailer everytime then you can make note of what the gauge is reading everytime you scale, however if you are constantly swapping trailers I would not rely on it.
  4. #4
    Malaki86's Avatar
    Malaki86 is offline Senior Board Member Malaki86 is a trusted source of information and would probably pick up your dry cleaning. Malaki86 is a trusted source of information and would probably pick up your dry cleaning. Malaki86 is a trusted source of information and would probably pick up your dry cleaning.
    Aug 2004
    West Virginia
    3,878
    I've never had a trailer with a load gauge, but I really miss the tractor axle gauge that was in my last truck.
    Wanna play a couple online games that are absolutely free? These are the games I play on a very regular basis:
    Battle of the West & Mobs Law
  5. #5
    thejunkman is offline Member thejunkman is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    80
    Thats how you do it, scale at the truck stop, see your axle weights, and compare to the psi showing on the guage. mine is 60 on the tractor and 80 on the trailer. Or, ask your company, they may know what readings you should look for on that truck
    However you need to realease the brakes, and or/move some to get a good reading. and you must have full air pressure as well. Some of the more expensive ones, give you actual numbers, the others show a pressure, and are not dead on everytime, but are good to get a rough idea
  6. #6
    wesland is offline Rookie wesland is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jul 2006
    15
    not sure what type of trailer you are pulling but with my truck at 70 and trailer at 68 i am about perfect , this is for a dry bulk tank with a kw trk hope cyanide dont see this i know how those liquid guys feel about us dry bulk haulers lol
+ Reply to Thread
