+ Reply to Thread
Results 1 to 18 of 18
Thread: Test: What size tank requires a tank endorsement?
    Myth_Buster is offline Member Myth_Buster is on the right path.  You could probably safely loan them a quarter.
    Jul 2006
    Dark Side of The Moon
    172
    Default Test: What size tank requires a tank endorsement?
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    If it is a tank vehicle it requires endorsement.
    (b) Endorsement descriptions. An operator must obtain State-issued endorsements to his/her CDL to operate commercial motor vehicles which are:
    b)(3) Tank vehicles;
    Tank vehicle is defined as:
    Tank vehicle means any commercial motor vehicle that is designed to transport any liquid or gaseous materials within a tank that is either permanently or temporarily attached to the vehicle or the chassis. Such vehicles include, but are not limited to, cargo tanks and portable tanks, as defined in Part 171 of this title. However, this definition does not include portable tanks having a rated capacity under 1,000 gallons.
    I see no quantity for tank vehicles, except for portable tanks. Definition of portable tanks:
    Portable tank means a bulk packaging (except a cylinder having a water capacity of 1000 pounds or less) designed primarily to be loaded onto, or on, or temporarily attached to a transport vehicle or ship and equipped with skids, mountings, or accessories to facilitate handling of the tank by mechanical means. It does not include a cargo tank, tank car, multi-unit tank car tank, or trailer carrying 3AX, 3AAX, or 3T cylinders.
    So to answer your question, all tank vehicles require endorsements. However if the "tank" fits the definition of a portable tank and is rated under 1,000 gallons it does not require endorsement.
    So completely empty and cleaned out 48 foot tankers cannot be driven without endorsement, and portable tanks must have a rating under 1000 gallons to be driven without endorsement. If it is rated for 1000 or more gallons but empty, you require endorsement. However this is only for tanks that are designed to transport any liquid or gaseous materials. Cokers and other large non-transport tanks need not apply.
    Did I pass?
  3. #3
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    Tank Vehicle means any commercial motor vehicle that is designed to transport any liquid or gaseous materials within a tank that is either permanently or temporarily attached to the vehicle or the chassis. Such vehicles include, but are not limited to, cargo tanks and portable tanks, as defined in Part 171 of this title. However, this definition does not include portable tanks having a rated capacity under 1,000 gallons.
    Having had my tank endorsement all along, I've never worried, or even thought, about this. But, now, I'm a bit curious. LP tanks can range from 100 gallons to several thousand gallons. (the house in WI had a 1,000 gallon tank behind it) When delivering those tanks, are they considered as "portable"? Some I've seen would be over-sized loads to move as well. But, once they are delivered, they tend to remain stationary.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  4. #4
    Aug 2005
    3,181
    They wouldn't fit the definition unless they were specifically to transport material. If they're empty and remain stationary after delivery, they're not considered a tank vehicle.
  5. #5
    Oct 2005
    6,187
    Quote Originally Posted by allan5oh View Post
    Flatbeds aren't considered tank vehicles either, but I have seen them with a huge neoprene (I think) bladder, 40 feet long, and about 7 1/2 feet wide, and when filled, they are about 4 feet high. About 8 4" straps holding them down to the bed. And, whatever was inside was liquid. What are they classed as?
  6. #6
    Aug 2005
    3,181
    That would be a portable tank, and if the rated capacity was 1000 gallons or more, it is a tank vehicle. However that's only if the bladder is NOT used to transport liquids/gases.
  7. #7
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    I'm waiting for Golfhobo to give us the "official" answer.
  8. #8
    golfhobo is offline Board Icon golfhobo is well-known and should trademark his/her name. golfhobo is well-known and should trademark his/her name. golfhobo is well-known and should trademark his/her name. golfhobo is well-known and should trademark his/her name. golfhobo is well-known and should trademark his/her name. golfhobo is well-known and should trademark his/her name.
    Oct 2005
    the 19th hole / NC
    7,570
    Quote Originally Posted by Rev.Vassago View Post
    Sorry to disappoint you. I'm not interested in this little "TEST" from our resident "driver hater." I recently got my tanker endorsement while getting my Triples so I could pull these wiggle wagons. I guess that means I'm good to go with a full tank of nasty chemicals!
    So, it doesn't matter to me if it's a bladder on a flatbed or a tanker full of rancid milk! Just kick the tires and light the fires and I'm ready to roll!
    I didn't get to roll last night/today though, cuz they couldn't get the "local wusses" out to shuttle the local freight to the terminal, ergo.... nothing for me to haul to Kentucky! Dang I feel guilty enjoying this 3 day "snow" weekend!
    But, I noticed YOU didn't give an answer yet, Rev. You KNOW I never post an opinion till I see how wrong you are!
  9. #9
    Aug 2005
    3,181
    From what you guys see, anything wrong with my answer?
  10. #10
    Jul 2006
    172
    Allan5oh is correct, if the vehicle is a tank vehicle it requires a tank endorsement... No size is stipulated.
    Windwalker:
    Having had my tank endorsement all along, I've never worried, or even thought, about this. But, now, I'm a bit curious. LP tanks can range from 100 gallons to several thousand gallons. (the house in WI had a 1,000 gallon tank behind it) When delivering those tanks, are they considered as "portable"? Some I've seen would be over-sized loads to move as well. But, once they are delivered, they tend to remain stationary./
    Stationary home LP tanks cannot be transported with more than 5% of product. There are some limitation reguarding how the tanks may be transported. Typically the bobtail delivery trucks fill the home tanks on site.
    If the flexible tank is filled and emptied from the vehicle, it is a tank vehicle:
    Question 2: Are rubberized collapsible containers or ‘‘bladder bags’’ attached to a trailer considered a tank vehicle, thus requiring operators to obtain a CDL with a tank vehicle endorsement?
    Guidance: Yes.
    Be safe.
  11. #11
    Apr 2006
    9,411
    Quote Originally Posted by golfhobo View Post
    You are clearly incapable of answering a question on your own, and resort to picking apart the answers of others. You were given a wonderful chance to show some true knowledge on the subject, and you fell flat on your face with your non-answer. I will take this into light every time you attempt to pick apart the knowledge of others, and will constantly quote your non-answer. (which is funny because you pick apart MB's posts as non-answers).
  12. #12
    Apr 2006
    9,411
    And just in case you attempt to edit your post, I'm saving a copy of the original by quoting it.
  13. #13
    Oct 2005
    the 19th hole / NC
    7,570
    Wrong. As I stated, I was clearly DISinterested in this topic. YOU drug me into the conversation (which I had no interest in posting about. Hey! Can I call that a "personal attack on someone who hadn't even posted on this thread?)
    I show knowledge where knowledge is needed or when YOU misquote regs or rationale. I saw NO need to answer this question that related to nobody or nothing. And again I note that YOU failed to give an answer as well. So.... I guess YOU fell flat on your face as well.
    Like THAT would be an innovation for you! But.... whatever! I guess things on CAD ARE getting a bit slow eh? I guess when you are married to it, as you now are, you must "fish" for controversy. Personally, I now have other things that require my time.
    But, as a matter of fact, after reading the thread, I was GOING to throw my support behind Allan5Oh's answer. But, before I could DO so, M/B confirmed it to be true (to the extent that he has that power.)
    However, as I"ve said many times before..... I don't talk about things that I don't know about, and I don't know that much about tanker yanking! Never needed to. But, if I ever DO.... be assured that I will know ALL that I need to know. And probably, as always, more than YOU.
  14. #14
    Jumbo's Avatar
    Jumbo is offline Senior Board Member Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street.
    Aug 2006
    Northern Wisconsin
    2,102
    My guess is 10 gallons. Same size as my hat.
  15. #15
    ApacheKid is online now Rookie ApacheKid is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2012
    North Central Kansas
    7
    What about a Pneumatic trailer, is it considered a tanker?
  16. #16
    Fredog is offline Senior Board Member Fredog is a trusted source of information and would probably pick up your dry cleaning. Fredog is a trusted source of information and would probably pick up your dry cleaning.
    Apr 2005
    North Georgia
    3,665
    Quote Originally Posted by ApacheKid View Post
    NO, it's not
  17. #17
    Jan 2012
    7
    Thanks Fredog for the quick reply!
  18. #18
    Oct 2005
    the 19th hole / NC
    7,570
    And thank YOU, ApacheKid for dragging up a very old post that reminded me of all the fun I used to have "debating" The Rev!
    With HIM gone, I've turned into a milquetoast poster just trying to "get along" with the other kids here. I was SO much more fun back then! LOL!
  19. This ad will disappear if you login
+ Reply to Thread
