Results 1 to 3 of 3
Thread: How to get rid of black sediment in the fuel tank?
    tracer's Avatar
    tracer is offline Senior Board Member
    Mar 2007
    Cambridge, Ontario, Canada
    1,316
    Default How to get rid of black sediment in the fuel tank?
    I recently noticed some black stuff at the bottom of the fuel tank. It looked like oil. I don't think I have any drain taps ... Does anyone know if you can buy some chemical that might clean this? It might be algae but I doubt it. The passenger side tank seems clean, it's only in the tank on the driver's side. I only saw it by accident as the sun was shining directly into the hole when I was fueling. Thanks.
  2. #2
    Maniac's Avatar
    Maniac is offline Senior Board Member
    Sep 2004
    Northeast
    963
    The only way is to drain it, there should be a drain plug, otherwise you will have to siphon it when the tank is completely empty
  3. #3
    mitchno1's Avatar
    mitchno1 is offline Board Regular
    Oct 2010
    new zealand
    365
    could be the bug can get a killer agent but still clean whole system blow fuel lines and steam clean tanks and add agent to fuel otherwise it gives system s---
  4. This ad will disappear if you login
