Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
Thread: Do you need a 10'1" tandem to move this load?
  1. #41
    Heavy Duty is offline Board Regular
    Sep 2007
    414
  2. #42
    oneliner is offline Rookie
    Aug 2010
    Ontario Canada
    30
    Quote Originally Posted by tracer View Post
    The run is 2,000 miles long!
    Hey.... what happened to staying in the midwest where there's lots of freight to get you back to Ontario?
  3. #43
    tracer's Avatar
    tracer is offline Senior Board Member
    Mar 2007
    Cambridge, Ontario, Canada
    1,316
    Quote Originally Posted by oneliner View Post
    Well, what am I supposed to do when there's no loads going TOWARDS Mid-West? Drive 800 miles from Montreal QC empty so that I can pick up $3/mi freight going 500 miles back to Ontario?
  4. #44
    Sep 2007
    414
    Looks like there is a lot of good loads going to Canada right now, hope you can catch one.
  5. #45
    tracer's Avatar
    Mar 2007
    1,316
    Quote Originally Posted by Heavy Duty View Post
    The rates are good but all the loads are going to the Alberta tundra. No sun lotion on board required. Felt boots a must.
  6. #46
    tracer's Avatar
    Mar 2007
    1,316
    Here's another load where a 10'1" spread might work better... I'm waiting to hear from the Agent and I'm picking up steel plates. All are 37' long, 9.6' wide, and 2 inches high. The weight is 45,201 lbs. I hope I can distribute it equally between the trailer and truck axles by some creative use of the dunnage. I need to put more weight on the truck axles.
    Just scaled the truck with these steel plates and ... I was right about the 10'1" spread. I'm legal ... but the load on the drives is WAY less than on the trailer. Either a tridem or 10'1" tandem would work much better and help distribute the load properly.
  7. #47
    rank is offline Senior Board Member
    Oct 2006
    2,041
    You could have DH 600 miles to Baltimore. Your cpm must be under .90. Would`ve cost you approx $500 to load $2.50 - $3.00 freight and you could have been ready to load the next AM. You could just do Baltimore - Toronto - Chicago - Montreal and never be more than 600 miles from a $2.50 reload. All that chaining and unchaining can be hard on a guy tho LOL.
  8. #48
    specialkay is offline Member
    Dec 2008
    Southern Ontario
    90
    A bigger spread would have been worse. Your 60" spread helps put more weight on the drives in that situation. The further ahead the front axle of the trailer axles is means the less weight you have on your drives. It's hard to explain but do a drawing and you'll see what I mean.
  9. #49
    mgfg is offline Member
    Feb 2011
    110
    Quote Originally Posted by specialkay View Post
    I tried discussing that exact point but it was ignored.
  10. #50
    tracer's Avatar
    Mar 2007
    1,316
    One thing you're missing is that my 61" spread is only rated for 34,000 lbs! If this was a 10'1" spread, I'd be legal at - let's say - 36,500 lbs. However when I have 36,500 lbs on my axles NOW, I can get a ticket for being overweight.
  11. #51
    Dec 2008
    Southern Ontario
    90
    The 10'1" spread would be better overall but the way I read your post was that you were upset that your drives were so much lighter than the trailer tandems. Sorry for the confusion.
  12. #52
    tracer's Avatar
    Mar 2007
    1,316
    That's why I think it's great to have the front axle slide from 121" to 72" position, while the rear axle is fixed as far back as the kingpin rule allows. I'd use the long spread only when it's required and stick to the 72" spread most of the time for better fuel efficiency and longer tire life.
  13. This ad will disappear if you login
