Results 1 to 10 of 10
Thread: peterbilt 387 Fuse box or relay box
    nsxman2001 is offline Member
    Nov 2005
    Mount Vernon, NY
    181
    Default peterbilt 387 Fuse box or relay box
    I was wondering does anyone know how to reset the fuse box or circuit breaker on a peterbilt 387. My radio fuse blew out. I remove the glove box and there are no fuses just a red light on the fuse box indicating the radio fuse is Out..
    thanks in advance[/list]
  2. #2
    GMAN is offline Administrator Board Icon
    Feb 2005
    Tennessee
    15,247
    Some may have a switch. Just push the switch the other way and that should do it. If there isn't a switch then you may need to go ahead and replace it.
  3. #3
    TK THE TRUCKER's Avatar
    TK THE TRUCKER is offline Senior Board Member
    Jul 2004
    Macedon Center,NY
    1,025
    The main fuse/breaker assembly is under the hood on the passenger side mounted to the firewall next to the windshield washer fill tube. If you have no luck in there, check under the bunk on the passenger side, there's some electrical items in there. I'd go find mine now but it's 5 degrees outside...brrrrr 8) 8)
  4. #4
    Jul 2004
    Macedon Center,NY
    1,025
    There's also a chance you have an in-line fuse right behind the radio :wink:
  5. #5
    Nov 2005
    Mount Vernon, NY
    181
    I looked under the hood and there are no fuses for the radio there. the only place that have a fuse is behind the glove box but there is no leaver to reset the fuse or a way to take it out. I have not taken the radio out but I can see the back of the radio and I do not see a fuse behind there. MY truck is and 06 model not sure if they are all the same from 01 up. Also under the bed has fuse for the bunk and the trailer..
    thanks
  6. #6
    Why don't you read the manual?
  7. #7
    Feb 2005
    Tennessee
    15,247
    If you have an owners manual it should tell you exactly where the fuses are located. If you have fuses behind the glove box, I would check there first. Their is usually a grid on the back of the glove box or near by that shows what each fuse or breaker is assigned. Most fuses can easily be checked visually. If the filament is broken, then the fuse is bad. With breakers, you can sometimes tell if they are bad because they get very hot. My guess is that you have a fuse that is blown. If the fuse isn't behind the glove box I would check underneath the steering column. Some trucks have fuses and breakers in that area. If you cannot find it and don't have access to an owners manual, you can always call a dealer and speak with their service department. You could also just start taking out fuses and check them, one at a time. Fuses for the radio should be color coded and easy to spot a blown or damaged filament.
  8. #8
    Nov 2005
    Mount Vernon, NY
    181
    Thanks Gman
    steve I did read the manual not really alot of information there about how to reset breakers
    thanks anyway
  9. #9
    Mar 2008
    6
    Don't know about yours, but my '03 pete has a fuse box on the firewall, between the clutch pedal and the drivers door
  10. #10
    Nov 2005
    Mount Vernon, NY
    181
    Thanks but I end up reseting the fuse breaker by unpluging it.. The radio is now working.
  11. This ad will disappear if you login
