I have a Honda 3000is. It is strapped to the truck by two 2 inch rachet straps. DOT has never even looked at it. The wire connections have to look pro. It pretty much runs my stuff and burns probably 2 1/2 gallons for eight to ten hours of air conditioning or heating with a heat pump. I have a large microwave and it will not run 14,000 btu of air conditioning and the microwave at the same time. You would really need a 5000 watt for that heavy of use.
Yes it is on the catwalk. I have a rubber flap down first to cusion it from the rough alumimum and a strap on each side hooked to the frame. There are many truck running generators. My setup is a little more complicated where I have a 2000 watt inverter in line with it that also charges the batteries. I also have five deep cycle batteries. But I ran it with the generator only at first. Just so the wiring is installed neat and secure it is ok. A small inverter, 29.95 at walmart will run any tv well and not take the batteries down in 24 hours.
You need to look into the air conditioner good. It will amaze you how big you need to cool the truck on a hot day. I havce 14.000 btu and it is not big enough but tolarable. On a 90 degree day it will get to 85 or so in the truck. But without it goes to 110 degrees or so. Test borrow one or buy one at Wallmart and return it if not big enough. Set it up on a window and tape some plastic on a hot day to get an idea. then you need a generator big enough. The 14,000 draws 1600 watts on run and dims the lights when the compressor starts with the 3000 watt generator. When I first got it, (the air) till it broke in, sometimes it would pop the circuit breaker on start up.
In the winter a ceramic heater draws about 1500 the biggest you can get. It will heat you ok till it gets real cold. I am good down to 10 or 15 degrees and colder thanthat you need to let the truck run anyway. I can give you a couple of tips, the truck system needs to be put on recirculate while stopped, the system will bleed hot air in and cold air in the winter. I don't know what post you read, but I have a bunch of stuff in here, coffee maker, toster, 2 1/2 cubic foot freezer, refridgerator, 27 inch high def tv, dvd, and so on. I can park at night with no generator and be ok except for air cond. I also have a fan mounted in a vent to get some air. Flys are a problem. With gas at 2.40 it takes about 4.50 or 5.00 for a 12 hour run with the generator, now it is up to 7.00 or so with 3.00 gas. I also have remote start on my generator, a real help. I found that before the remote I would run the generator all night when i did not need it so that it woud be running in the morning when the sun hit the truck. Of course I drive most of the night and sleep later.
An inverter with a charger is a great thing. I have left the markers on all night and the batteries low in the morning. Woops, but the generator running the inverter charges them back up in a half hour or so. Something to remember, the industry standard for house current at 115 volts is 1500 watts and it does allow a surge to 20 amps or so to start a compressor ok. 'RV units do run up to 30 amps and that is what I run, but you cannot run two full 115 volt loads on the system. Mine is 3000 watts full current and 2700 run.
If I was to do this over again knowing what i know now, the money would have gone into a 3000 or 4000 watt inverter with all the stuff running on the inverter and a generator to keep the batteries up. Of course that would take some serious batterys.
