+ Reply to Thread
Results 1 to 9 of 9
Thread: MPG on 500hp 390 rear?
    okieoo is offline Member okieoo is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2007
    67
    Default MPG on 500hp 390 rear?
    98 Freightliner c120.
    What mpg average should one expect running southern midwest,no mountains?
    Detroit 12.7 500,
    Sleeper 70" Condo,Wheel Base 240"
    Transmission Super 10,Tire Size 11R24.5LP,
    Suspension Air Ride Frame Steel,
    Axles Tandem Interior Signature,
    Rear End Ratio 3.90
  2. #2
    marylandkw's Avatar
    marylandkw is offline Senior Board Member marylandkw is a trusted source of information and would probably pick up your dry cleaning. marylandkw is a trusted source of information and would probably pick up your dry cleaning.
    Sep 2005
    Maryland
    733
    Don't know for sure but you should be able to see at least 7 or so with that setup.
    The number one factor in fuel economy is YOU, the driver. I managed to get 7-7.5 out of a cat 550 with an 18 and 4.11 rears. When I had a driver in the same truck it got 4.5. (reason number 72537 why I don't have drivers anymore)
  3. #3
    Lewis friend is offline Board Regular Lewis friend is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2007
    245
    I had a very similar setup.
    I think you can get at least 6.5 as long as you don't push it too much.
  4. #4
    Feb 2007
    67
    Ty for the replies.I didnt think it would get that good of mpg.
  5. #5
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    the truth.... i get 7.2- with some hills & 8.5 m.p.g. on flat. that is cruise set at 62 m.p.h in a 70 m.p.h speed limit area carrying 46,000 lbs. doing the same runs at near top end 69-72 mph i get 5.7- 6.0 m.p.g. & that is on a mil mi cabover with a 11.1 detroit. your driving makes a huge difference.
  6. #6
    tracer's Avatar
    tracer is offline Senior Board Member tracer is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2007
    Cambridge, Ontario, Canada
    1,316
    Here's an interesing formula that can help determine the engine's RPM at cruising. If you know the recommended engine speed in rpm, the calculation will tell you what speed you should run at.
    To do this, you should know: your transmission top gear ratio, your rear axle ratio, revolutions per mile of your tires, desired cruising speed. It may take awhile to find out your tranny top gear ratio, and rev/mile of the tires, but once you have them, you can pinpoint exactly the RPM you'll get at the particular speed with your axle ratio.
    Example: 13 speed Eaton transmission with 0.73 top gear ratio, 4.11 rear axles ratio, 22.5 tires with 495 revs/mile will have the truck cruising:
    56 mph at 1,386 rpm
    58 mph at 1,435 rpm
    60 rpm at 1,485 rpm.
    I did this calculation for a Cummins engine, and they recommend to be between 1,400 and 1450 rpm for maximum fuel economy.
    Formula:
    RPM equals CRUISING SPEED IN MPH times TOP GEAR RATIO times AXLE RATIO times REVS/MILE divided by 60.
  7. #7
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Yup around 98 is about the best year for detroits that get good fuel mileage. I know someone with a 500 detroit and he gets 7.5-8 regularly.
  8. #8
    rank is offline Senior Board Member rank is on the right path.  You could probably safely loan them a quarter.
    Oct 2006
    2,040
    We had a '01 Sterling with that setup. 18 speed + 3.70 rear IIRC. It got 5.5 running up and down I81 between Baltimore and Alex Bay. Grossing 80,000lbs southbound and 35,000lbs northbound.
  9. #9
    BanditsCousin's Avatar
    BanditsCousin is offline Senior Board Member BanditsCousin is on the right path.  You could probably safely loan them a quarter.
    Jun 2004
    Chicago, IL
    3,801
    I'd say around 6.5-6.7, depending on how you drive it. hats killing your mpg's is the 3:90 rear ends. You'd get over 7mpg easily with a higher ratio (higher overall gearing)
    Mud, sweat, and gears
  10. This ad will disappear if you login
+ Reply to Thread
