Results 1 to 3 of 3
Thread: Average Fuel Burn Rate Of Idling Trucks and Motorhomes
    Jul 2008
    Pahrump, NV
    59
    Default Average Fuel Burn Rate Of Idling Trucks and Motorhomes
    On average, what is the per hour fuel burn rate, in gallons, of an idling OTR type truck that does not have an APU?
    Same question for a typical 35- or 40-foot class A, diesel-pusher motor home. What is the typical fuel burn rate in gallons per hour when idling?
    Thanks.
  2. #2
    Pack_Rat's Avatar
    Pack_Rat is offline Member
    Jan 2008
    Michigan
    107
    A OTR truck averages 1 to 1 and half gallons an hr. I would say a motor home would be close to that.
  3. #3
    TomB985 is offline Board Regular
    Sep 2006
    Columbus, OH
    463
    That also depends on which motor and idle speed.
    In order to idle for an extended time when needed, my last company set the truck so you had to idle it up to ~900 RPMs. Doing so burned 12 gallons in an 8 hour period, on a Detroit Series 60
    My current company does NOT set their trucks like that, and at a 600 RPM idle, my current Cat C15 burns 5 gallons in an 8 hour period.
  4. This ad will disappear if you login
