What weight and oil manufacture do you use for the rear differentials? I need a good oil, but prefer not to use synthetic.
Isn't gear lube 90 weight? BOL
I USE THE JT-7 90/140
Most rears and trannys now use a 80w90 synthetic oil. Brand name not so important.
A superior driver uses superior judgement to avoid situations which require superior skill.
We use 75W90 synthetic in the Meritor rears, and 50W synthetic in the Eaton Fuller transmissions.
We sample it yearly to keep an eye on it.
Even if the samples test OK, it gets changed every 200,000 miles.
| Trucking
Companies | Trucking
Job Search | Online
Job Application | Trucking
Links | Truck Drivers
Message Board | Contact
Us | Site Map
