Originally Posted by
Fozzy
Fredog
west_coaster
I am a cop, and I patrol the freeway. I will not stop a truck going 65 or under unless they're doing something really stupid, and our truck speed limit in Oregon is 55. If I do stop a truck for speeding, its because it's speeding, not to generate revenue
. The last thing I think about when I issue a speeding citation is the money it may bring in. The speed limits in most states are set by the state legislature, so the way to change it is get a petition, get it on a ballot, and vote.
I personally think that the speed limits on the freeways in Oregon are too low (65 cars, 55 trucks). I do know that the original federally set speed limits of 55mph were due to some smart guy back in the black and white days determining that the kinetic energy built up by an object increases exponentially after 55mph, thus causing quite a bit more damage at 65 vs. 55 (compared to 45 vs. 55) I'm not sure why, I'm not smart enough to figure out the math of the equation.
Another thing to think about is cost vs. benefit. If you run faster, you will run more miles in a day, but you will also burn more fuel (Fozzy is right!) and run your truck at a higher rpm's (= more wear and tear on stuff). You also increase your stopping distance and decrease reaction times. When you add in adverse weather conditions, it quantifies the problems. If you can justify the benefits over the cost of running consistently faster, then you should run fast in the states that you can legally do it in. I know that California and Oregon have both stated firmly that they will not raise the truck speed limits, citing safety reasons. I'm not sure if it's true, but I do know that guys like you and I will probably never be able to influence any state legislature, we're just not that rich.
That's my rant.
W.C.
No matter what the speed limit is or what the reason for it, having split limits is more dangerous than having one limit..
IF there was some stretch of road ANYWHERE , where people actually did the speed limits. The whole point is basically worthless and better yet unprovable because there is no way to get real data. There is no real proof anywhere other than someone's pet theory that this split speeds are dangerous. Name the road where the data was taken that proves the myth...
“In 1963, David Solomon reported that deviation from the mean speed of traffic in both the negative and positive direction contributed significantly to the occurrence of accidents. In fact, Solomon showed that vehicles traveling 10 to 15 mph slower than the mean speed of traffic were much more likely to be involved in accidents than vehicles traveling slightly above the mean speed. Solomon presented his results in the now famous ‘U-shaped’ curve, which relates variance from mean speed to involvement in accidents.
“Solomon’s study was conducted on two- and four-lane main rural highways. A similar analysis was conducted on the interstate that has higher operating speeds. The data for this study was collected by 20 state highway departments, including Ohio. The analysis showed the same ‘U-shaped’ curve for interstate highways and generally lower accident involvement rates, again confirming the safety benefits of the interstate system. The analysis also showed the variance in speeds on the interstate was between 5 to 7 mph, approximately half that of non-interstate facilities.
“The National Highway Traffic Safety Administration subsequently contracted with Indiana University to conduct a speed-safety study. This study confirmed the ‘U-shaped’ curve established by Solomon and the interstate study.”
Ohio truckdriver and OOIDA member Dick Chambers told the committee, “By raising the limits on the major interstate systems, the state would give truckdrivers a greater incentive to drive on the safest roads in Ohio. Our interstate highways have limited access, are wider, have banked curves and, as many of you know, were designed for speeds in excess of 65 mph.”
—by Keith Goble, staff writer
Keith Goble can be reached at
kgoble@landlinemag.com.
ok Fozzy, go ahead and tell me why this study isnt legitimate
