Your welcome WarHorse and Dave, your not a bad poster, I do it too especially if it has 4-5 pages to it.
Well, having the same problem in the house certainly does eliminate the inverter and the truck. The only common factors are the power source and the computer itself. Sounds like a new supply should take care of it for you. Good luck.
Destroy the cities...and they will rebuild them.Destroy the farms...and grass will grow in the streets of the cities.
Destroy the economy of the blue-collar worker...and grass will grow in the executive offices.
The bill has come due.
Hope it is the power cable and not the plug on the laptop its self that is screwed up.
My old laptop had the plug screw up so it would not make good contact with the power cable.
Well anyway I am glad you are getting it narrowed down.
Originally Posted by Uturn2001
Yeah, I have two Toshiba Satellite notebooks-- and can tell you-- the DC Power jack is the #1 most common problem with a Toshiba-- the less times you plug/unplug the better off you'll be-- then you just have to worry about breaking/bumping the jack.
Here's a link to a DC Jack "work-around"-- this worked for me with my first Satellite A75 for couple years-- of course I modified the work-around slightly- I soldered a power cord "pig tail" to the motherboard-- ( actually used a Coleman Cooler replacement cord( you know the one you can buy inside the truckstop- that has the red/blue blade connector) that way I could unplug the AC adaptor without stress or strain on the motherboard.
http://www.laptoprepair101.com/lapto...ck-workaround/
[quote="headborg"]Thanks Borg. I'll find out if that is the problem soon enough.Originally Posted by Uturn2001
"The truth is one; the sages speak of it by many names." - The Upanishads
I bought one of those adapters and it's running fine. I did get a Blue Screen of Death, which is pretty unusual, but it didn't appear to be power-related.Originally Posted by Drew10
Right now it's humming along and no warning beeps from the inverter, so I'm happy.
Thanks Drew!
It occurred to me that I'm inverting DC to AC, then the computer is reversing the procedure. Waste waste! :P
Good, Im glad its working for you.....Yeah it does seem to be kind of a waste to convert DC-AC...just to convert it back to DC again.
| Trucking
Companies | Trucking
Job Search | Online
Job Application | Trucking
Links | Truck Drivers
Message Board | Contact
Us | Site Map
