Im starting to get stuff readdy for my truck now. And was wondering what you guys recommend. I preatty much dont know anything about them. Ill be running a fridge, a microwave and a TV. Thats probally all. TIA Mike
I have a Cobra 1500 watt that I picked up at a T/A. Paid about $20 for it after wiping out my points. It runs everything with no probs.
Wanna play a couple online games that are absolutely free? These are the games I play on a very regular basis:
Battle of the West & Mobs Law
Is this on a company truck?
If so are you sure that you can install a large inverter? If you do not know then you need to wait to find out.
Assuming you can install a large inverter, which will need to be direct wired into the batteries, I suggest you get at least a 1500 watt, and no bigger than a 700 watt microwave. Xantrex and Tripp Lite make the best inverters on the market, but you will pay more for them. Vector makes a decent one.
I would also suggest getting a 400 watt inverter and using it just for you TV.
yea its a company truck and we can have them. My trainer has a 1500 watt so he says its okay. I guess i need a 1500 watt???? I dont know. thanks for the response>
The reason we are saying at least a 1500 watt inverter is because a microwave as well as a small dorm type fridge takes a lot of power upon startup.
If it was not for that a 1000 watt would do just fine.
In addition, the reason I suggest a second inverter for your TV, which is a plug in type, is so you will not have as much of a headache trying to run cords across your sleeper to plug everything into one inverter.
Been there, done that, and in some trucks it is easier said than done.
like this? is this good
http://www.amazon.com/Xantrex-Techno.../dp/B0009MGOQ8
get a d/c tv. you wont be sorryOriginally Posted by Uturn2001
I know people who have had little problems with them, I on the other hand have had 3 and none lasted more than 6 months before something went wrong with them.get a d/c tv. you wont be sorry
I still have a 13 inch tv/vcr that is about 4 years old and works great that spent 2 1/2 years bouncing in a truck and a 13 inch tv/dvd player that is 2 years old that has about 18 month of truck use that still works. Both of which are 110 v.
So the link above, is that a good one to get? anyone?
Yes, that would be a good one.
I have a small inverter, 2 outlets, 350watt (600peak). I hear horror stories about the larger inverters causing wiring problems and shorting circuits. I've never seen these incidents first hand though, and don't plan to since i own my truck.
Mud, sweat, and gears
I can't see how the wattage output of the inverter would affect the possibility of wiring shortouts. Shorts would be caused by a bare wire touching metal when electrified.Originally Posted by BanditsCousin
I have two enormous car audio amplifiers in my trunk. 4 gauge cable from the battery pos to a 30 amp fuse 20 inches away, then more 4 gauge going to the trunk. Within one foot of the amps, the 4 gauge goes into a double 20 amp power distribution block with two 8 gauge wires going straight to the amps. They draw a lot of juice and as long they are properly wired with fuses or breakers, fires can be prevented.
| Trucking
Companies | Trucking
Job Search | Online
Job Application | Trucking
Links | Truck Drivers
Message Board | Contact
Us | Site Map
